Roomba 550
Roomba 550
Hi
my roomba 550 start flashing red circle when insert battery (full charged battery on another roomba)
cleaned battery contacts
no beep no function any button
no water damage
replaced 8mhz crystal
no water damage
Re: Roomba 550
Your Roomba may have a defective D58.
http://www.robotreviews.com/chat/viewto ... &hilit=D58
Re: Roomba 550
thanks for your reply
its not charging problem because i have 3 good full charged battery and working roomba
the problem is when i insert battery its start red blinking whitout power button press and not stop red blink until remove battery
sorry for bad English
- Robot Master
Re: Roomba 550
A shorted D58 could very well cause the clean light to pulse red or amber. It is the most likely device failure to cause this.TechGuy wrote:Your Roomba may have a defective D58
Re: Roomba 550
Normally, Roomba blinks the Clean light in red or orange to indicate that it is in the high current charging mode.rifziyad wrote:thanks for your reply
The false charging state that Gordon was referring to in that thread is the "blinking red/orange clean light without plugging in your charger" This is exactly what your Roomba is doing.
Yesterday, I repaired a 530 with the same blinking red/orange clean light by replacing the D58.
Re: Roomba 550
just removed D58
still same. i did check diode with multimeter reading ok
i going to remove my working roomba and replace D58
Re: Roomba 550
The D58, which I took out from the blinking orange clean light, was checked with a multimeter and it seems fine. But its leaky current will keep the Roomba blinking orange clean light.rifziyad wrote:...
- Robot Master
Re: Roomba 550
Removing D58 would stop the CLEAN button from pulsing if it were the problem. There may be another short.rifziyad wrote:just removed D58
still same.
Why?!i going to remove my working roomba and replace D58
Another reason the Roomba would think a charger is connected is Inverter U15 pin 10 is sourcing Sys_Rtn to the MCU.
This Drawing: http://www.robotreviews.com/chat/downlo ... &mode=view
Re: Roomba 550
thanku for replay and schematic
just disconnected pin 10 of u15
sadly still same
q18 short?
sadly still same
q18 short?
- Robot Master
Re: Roomba 550
I can't tell you what the MCU will read on a floating input.
One would have wanted to measure the voltage on pin 10 U15, 0V charger connected, 5V no charger connected.
- Robot Master
Re: Roomba 550
What was the bot doing before replacing the crystal osc.
Re: Roomba 550
on pin 10 U15 5.018 volt without charger connected
Re: Roomba 550
Same problema1robotrepair wrote:What was the bot doing before replacing the crystal osc.
i thought its crystal problem i was wrong
Re: Roomba 550
removed q36
same problem
you have full schematic?
same problem
- Robot Master
Re: Roomba 550
The next step would be to verify 5V on pin 32 of U28 without charger. After that, I would check all the regulated power, 5V and 8V.
Re: Roomba 550
there is 5 volt on pin 32 without charger
Re: Roomba 550
can you please guide me to check regulated 5 volt and 8 volt?
Re: Roomba 550
is there any full schematic for roomba 550?
- Robot Master
Re: Roomba 550
The 5V should be checked with an O-scope @ L1 where it connects to C287, LC filter. It should show very little ripple.
8V @ U27, 78L08 TO92 pin 1 http://www.st.com/content/ccc/resource/ ... 000446.pdf
Re: Roomba 550
i have Rigol D1102E scope but i am not an expert on O-scope reading (still learning)
i will try to check and let you know in 30 minutes
