disabling sound ?
slowbass
disabling sound ?
Post by slowbass »
Hello,
Do you know if it's possible to disable the different sounds the Bravaa makes ? At night, it's a bit too loud.
Re: disabling sound ?
Post by vic7767 »
There is no button sequence that is known to perform a speaker shut-down. Possibly adding a switch mod could work.
slowbass
Post by slowbass »
Thanks but too complicated for me !
Viroos
Post by Viroos »
Just cut off the mic.
Post by vic7767 »
Viroos wrote:Just cut off the mic.
Dis-assembly will be required to access the leads that are connected to the sound generator (speaker)
Post by vic7767 »
Actually upon dis-assembly it appears that to disable sounds from your Braava will require one to unmount the SP1 component from the circuit board.
susantx3
Post by susantx3 »
Has anyone removed the speaker?
Are there any disassembly videos for the M6
The M6 takes forever to complete and needs to be run at night. Irobot has confirmed the speakers cannot be turned off. I have no need for a musical tone to go off upon starting and completing a mission.
Thanks in advance
ps0001
Post by ps0001 »
I don't own one, and I haven't seen any teardowns online, but it would be the same procedure Vic outlined above: disconnect the speaker (unplug it, install a switch, de-solder it, etc.).
susantx3
Post by susantx3 »
[quote="ps0001"]I don't own one, and I haven't seen any teardowns online, but it would be the same procedure Vic outlined above: disconnect the speaker (unplug it, install a switch, de-solder it, etc.).[/quote]
I have disconnected the speaker on a Roomba, but needed the Roomba disassembly video. Have not been able to find that for the M6. The loud ringtones seem to be an odd choice for a product that really needs to be operated at night. Neato now gives you the choice to turn off the speaker.
In any event, thanks for the reply
