It’s designed to automatically cut up to 1/4 of an acre of grass space (If your yard is larger, remember to subtract the area taken up by your house and driveway and gardens and such to figure out how much grass space you have). It can work on inclines up to 20 degrees and the cutting height is adjustable from 1.6 to 4 inches.
The mower will automatically cut your grass every day on the schedule that you set, automatically returning to it’s charging base whenever the battery needs charged and whenever it is not scheduled to mow. It also has a rain sensor that can be enabled to have it return to the base whenever it starts raining.
Once you install the boundary wire, which tells the mower where to mow, you can set it’s schedule and never worry about cutting your grass again.
I’m looking for $700 shipped
