Just read piokrza's disassembly post and saw the photos of his Trilo that looks just like mine. My unit has been sitting for a couple of years against its charger, but I failed to use it. Last night I tried and it will run for only 10-12 minutes a shot, but cleans as ferociously as it always did.
Piokrza mentioned accessing/removing/replacing the battery in your post, but didn't say how that was done. Can someone please help me? Can't find any battery-swap instructions or photos online.
Please help. Kicking myself that I let the Trilo just sit idle in my dining room for so many years. Thanks in advance for any clarification you can provide.
How to Change Batteries in Trilobite?
Re: How to Change Batteries in Trilobite?
There is an easlily accessable battery compartment underneath the robot.
Its just 2 screws to be able to open the lid at the bottom of the robot.
You need 2 replacement batteries:
2200 mAh
Ni-Mh
215.00 x 67.00 x 22.50 mm
18 V
With this type of connector:
If i remember correctly its the same batteries in some models of Husqvarna Robot Lawn Mowers as well.
Ebay link below:
https://www.ebay.com/itm/Battery-For-El ... SwfVpZkmkD
2200 mAh
Ni-Mh
18 V
Ebay link below:
Thanks for the reply. What about the screwdriver you used?
Never mind. Found this in kitchen drawer.
