home base IR sensor test
Hi I am not sure if anyone can help in any way I have a Roomba docking station and if i hold my camera at it i see to Pink led's flashing in the front but the one on top does nothing is there a reason for that and if so how do i test it and where can i get a replacement from Thank you
- CodaCM
- Robot Master
- Contact:
Re: home base IR sensor test
Welcome to Robotreviews!shielings1 wrote: ↑March 7th, 2025, 11:24 am Hi I am not sure if anyone can help in any way I have a Roomba docking station and if i hold my camera at it i see to Pink led's flashing in the front but the one on top does nothing is there a reason for that and if so how do i test it and where can i get a replacement from Thank you
This is totally normal, that is the RCON sensor which is also found on the Roomba its self. On the robot, it’s used to see the home base and virtual walls. On the home base, it’s so the base can see the robot.
CodaCM
Most "Active" Forum Mod
Roomba Discovery 2x - 2010
Roomba 410 - 2022
Roomba 880 - 2022
Scooba 330 - 2023 (totally fine just bad battery)
Neato Botvac D85 - 2021 (Dead Mobo)
Neato XV Signature - 2023 (Dead Mobo ) I totally did not cause it
Roomba 410 - 2022
Roomba 880 - 2022
