electrolux trilobite 2.0 - disassembling, photos
Some pics. Look at the cleaning head. It doesn't have bristle brush but rubber roller (or something)
- Attachments
- trilobyte_neu1.jpg (44.72 KiB) Viewed 21574 times
- trilobyte_hinten.jpg (22 KiB) Viewed 21574 times
- trilobyte_hinten2.jpg (19.23 KiB) Viewed 21574 times
- trilobyte_display.jpg (24.63 KiB) Viewed 21574 times
- trilobyte_akku.jpg (27.19 KiB) Viewed 21574 times
- trilobite5.jpg (6.95 KiB) Viewed 21574 times
- removable_roller.jpg (16.16 KiB) Viewed 21575 times
- magnetic_strip.jpg (21.88 KiB) Viewed 21575 times
- img0.jpg (13.34 KiB) Viewed 21575 times
- aufmacher_trilobite.gif (36.78 KiB) Viewed 21575 times
Re: electrolux trilobite 2.0 - photos
next 10 photos
- Attachments
- trilobyte_rolle3.jpg (25.82 KiB) Viewed 21574 times
- trilobyte_rolle2.jpg (27.22 KiB) Viewed 21574 times
- trilobyte_rad.jpg (23.03 KiB) Viewed 21574 times
- trilobyte_rad2.jpg (22.95 KiB) Viewed 21574 times
- trilobyte_offen5.jpg (38.2 KiB) Viewed 21574 times
- trilobyte_offen3.jpg (31.41 KiB) Viewed 21574 times
- trilobyte_oben2.jpg (27.23 KiB) Viewed 21574 times
- trilobyte_oben1.jpg (12.44 KiB) Viewed 21574 times
- trilobyte_neu3.jpg (44.46 KiB) Viewed 21574 times
- trilobyte_neu2.jpg (12.35 KiB) Viewed 21574 times
recent 10 photos
- Attachments
- trilobyte_unten.jpg (24.43 KiB) Viewed 21573 times
- trilobyte_unten3.jpg (26.11 KiB) Viewed 21573 times
- trilobyte_unten2.jpg (25.37 KiB) Viewed 21573 times
- trilobyte_staub.jpg (31.23 KiB) Viewed 21573 times
- trilobyte_staub2.jpg (22.49 KiB) Viewed 21573 times
- trilobyte_station2.jpg (17.08 KiB) Viewed 21573 times
- trilobyte_station1.jpg (13.7 KiB) Viewed 21573 times
- trilobyte_sensor.jpg (24.83 KiB) Viewed 21573 times
- trilobyte_seite2.jpg (11.84 KiB) Viewed 21573 times
- trilobyte_rolle.jpg (29.79 KiB) Viewed 21573 times
Here you have video where is comparison of Roomba SE with Trilobite. It looks like Trilobite can't deal with picking up very small particles of dirt (as an example: flour)
[video]http://www.youtube.com/watch?v=yRTplKFkJnM[/video]
- Fraggboy
- Robot Master
- Contact:
Thank you for the great photos!! How long does the trilobite run for? I'm curious due to the 2 sets of batteries. It would seem that it would run well over 2-4 hours on a single charge.
The vacuum motor has a nice weight on it. I'm sure it takes a little bit more energy to get it going, but once it gets up to speed, it would take less energy to keep it going..
It run only for 60 minutes on single charge which takes 2 hours. The vacuum motor is very big and the power consumption by robot is 90W.
- Fraggboy
- Robot Master
- Contact:
Wow!! That's crazy! That sucks that the motor consumes all of that and it still doesn't pick up as well as the Roomba..
Yes, unfortunatly it's true. It has a big suction power but it don't pick up as good as Roomba because of it rubber roller...Fraggboy wrote:Wow!! That's crazy! That sucks that the motor consumes all of that and it still doesn't pick up as well as the Roomba..
ps. Charging station consumes 60W
How did you remove front bumper ?
have you got some assembly manual ?
help me how to remove front bumper from trilobite.
thanks a lot.
thanks a lot.
Extra large capacity bin - 1.2l, is the best!
Wow. Who ever came up with the disk shaped vacuum cleaner idea should of filed a patent. They'd be rich!piokrza wrote:Here you have video where is comparison of Roomba SE with Trilobite. It looks like Trilobite can't deal with picking up very small particles of dirt (as an example: flour)
Ben
Homemade Telepresence Robot:
Not to hijack this thread, but does anybody know how to get the front bumper off of a Trilobite? I have googled but have not found a way to get it apart. I'm wanting to get into one of mine to check a hose. Thanks.
EW
Hi,eqwalker wrote:Not to hijack this thread, but does anybody know how to get the front bumper off of a Trilobite? I have googled but have not found a way to get it apart. I'm wanting to get into one of mine to check a hose. Thanks.
There is two little holes under, pushing with small pin you can open the locks.
But that is rather dangerous, because when reassemble, you might destrot the prosessorcard.
Why should you check the hose? error 15 perhaps?
Your Trilobite is wellcome to Finland for service
Best regards
Jari Viitanen
Trilobite service/Finland/Europe
oy.jvv.tekniikka.ab@dnainternet.net
I have a unit that will start up for a few seconds and then give an error 4. That error is not listed in the book. I have tried another set of batteries (out of one of my other Trilobites) and it still gives the error. I was wanting to see if there was something like a hose or something I could fix myself before having to ship it off to have it repaired. Any idea what that error means?
EW
Manufacture of robotic vacuum cleaner Trilobite
Re: electrolux trilobite 2.0 - disassembling, photos
I found some more pics - for me very impressive
I like!
Thanks for sharing!
Thanks for sharing!
Ben
I wonder if any other robotic vacuum cleaner has as big vacuum motor?
