Modernising The Electrolux Trilobite
Hey! My 11 year old ZA1 Trilobite gave me an error 11 the other day, and since I don't know if I'll be able to find a new mainboard for it anytime soon, or even repair it's current one, anyone think its possible to use some other control system for it? Possibly an Arduino? I have little experience in these matters, only used Picaxe stuff so far, so any input is greatly appreciated!
- vic7767
- Robot Master
Re: Modernising The Electrolux Trilobite
There is another controller you might consider: http://www.ez-robot.com/Explore/
I do like the look of that, especially since the programming side seems fairly simple, which is exactly what I need, thanks!!
I assume getting the thing moving would be a reasonably simple task, however I'm clueless how the ultrasonic sensors on the bumper of the Trilobite are set up, and how these would interface with any controllers?
- vic7767
- Robot Master
The drive motors would need to be controlled using H-Bridges that the EZ controller would then control, same thing with the ultrasonic sensors. The EZ controller has both ultrasonic and IR control interfaces already built.
Looking at the bumper, it seems each receiver has some form of serial communication as each only has 1 wire I think, and the emitter bar has a 4 pin connector. Would it be possible to solder these straight to the board of a normal off-the-shelf ultrasonic sensor, or is their some simpler way of doing it and I'm missing the obvious?
Did you make any progress on this? I have one ZA2 that has a main board that is beyond repair and another that isn't working properly ...
It would be nice to replace the mainboard and make Trilobite IOT.
I have had Trilobite, Roomba (x3) and a Navibot and the Trilobite had the best cleaning performance of all (but is a little noisy!).
